My wenge neck with rosewood fingerboard has some relief problems and I am wondering if it’s worth going to the expense, hassle, and time of sending it to Warmoth for a warranty inspection.
I simply can’t get more than maybe 8-9 thousandths of relief (measured at the 8th fret with the first capoed and the 21st held down). The truss rod nut is completely loose (modern neck construction) and I’ve performed the truss rod reset per the steps on Warmoths site. I’m using 10s with a hardtail bridge, if it matters.
Do to think I should send it in for the warranty inspection? Is there something I’m doing wrong? Is there something else I should look at or try?
