Seymour Duncan Zephyr Silvers
Actually, I submit to you that 2.794E+20 (+/- a dozen) angels can dance on the head of this particular pin.
Isn't the "secret" of Lace Alumitones that they use aluminium rather than copper? They also claim that they are a "current driven design" rather than a "voltage driven design," whatever that means.  :icon_scratch:
it's a completely different design. the coil is only like 3-5 turns then it goes into a copper step up transformer. i'm sure it reduces the production cost significantly. copper isn't cheap and it takes time to put all those thousands of winds on them.
Yep, the leg that the C.T.(current transformer) is attached to counts as one turn. It works just like a transformer and boost the signal enough to drive the amplifier circuit. The original design called for the main piece to be made from copper. Very interesting design.
yeah. i just took a look and i kinda had it wrong. i always thought the cover was cut into a coil and was in series withthe transformer. well it's more like 1 turn or a pair of loops in opposite directions and the the transformer is more of a current probe clamped over that one loop. or you could look at it as the main plate is itself the primary coil of a transformer as well as the pickup. so yeah it's "current driven." instead of voltage being induced with a moving magnetic feild it's induced by circular currents in the main plate with basically no readable voltage. i'm honestly surprised this works at all. i wouldn't have thought it would be efficient enough to make near the output of a normal pickup. not that the efficiency matters if the load is near 0 (high ohms) but i wouldn't have thought the standard pot values and all could work in this type of arrangement.
