Set necks
He's also like a million years old, I seriously doubt he has too much to do with the whole thing anymore.  Still plays guitar every now and then though!
er, he's forgotten more than most of us will ever know about guitars.
he plays at the iridium club on monday nights and has special guests alot.
sheeeeeeeeeesh! show a little respect, guys........
Les is not about money;
1961, when Gibson changed the design without Paul's knowledge. He said he first saw the "new" Gibson Les Paul in a music store window, and disliked it. Though contract required him to pose with the guitar, he said it was not "his" instrument, and asked Gibson to remove his name from the headstock. Gibson renamed the guitar the "SG", and it also became one of the company's best sellers. (From wikipedia).
I  have nothing but respect for the man...I have five original Capitol recordings from the 40's and 50's and am constantly on the lookout for more, reasonably priced of course.  I also have an old issue of Goldmine that I bought just for the article on Lester the Inventor (multi track recording anyone?) I was just kidding around before.  I mean there is no more iconic figure in the history of the electric guitar, except maybe Leo, but then I have never heard him play....again JK!
Don't believe all you read in Wiki.....
Gibson's side of the story is a bit different.  For one thing, that nasty divorce, and royalties being split with Mary was part of it.  Second, Les at that time was a has been, having re-re-re-re-issued "How High the Moon" on several LPs, all doing rather poorly by any measure.  Gibson was losing money through lack of sales on the LP, and wanted to cheapen and modernize it.  And Les's 10 year contract had expired.
There are many inconsistencies in the Les Paul/Gibson story.  Gibson contends more credit than Les affords them (the basic design, the arched top, material choice), Les takes credit for things that are insignificant - the colors, the ill-fated trapeze bridge (that WAS his design), minutia.
Later, in early 68, Les says he called Gibson and told them that old LP guitars were selling for several thousands of dollars (not so in 68), Gibson claims they wanted the LP line back as it was, due to better commercial viability.
Its about the money.  Its always about the money.
-CB- said:
If you do the LP in mahogany, with boatneck or 59 roundback neck, in mahogany, and use TOM and StopBar, and something like BB Pro 1/2 or BB 2/3 combination, you'll get the tone, no matter what the snobs say.  Better yet, do it in a hollow body LP, so it matches what Gibson is doing now.
Funny that this should come up because I wanted to post a new topic asking about it.
Gibson loves to boast the benefits of their set neck design.  They claim it increases sustain.  But I've wondered if it would really make any discernible  difference.  I would think that if the joint is tight enough, there shouldn't be much difference.  It's not like there's "play" in a bolt-on that soaks up the vibrations and lessens sustain.  Those things are solid tight.  So it seems it should transfer vibrations through the neck and body like a glue, right?  But what do I know?
Soloshchenko said:
Does anyone have any idea how a DIYer would go about gluing a neck to a body a la Gibson. I know Warmoth base their builds on bolt ons but surely you could ask for no neck plate holes and have a go.
I have no idea where to start really. Does anyone know the processes or what glue to use? Has anybody tried doing this? Is it not just a case of gluing and clamping?
The Fender based bodies and necks are intended for bolt on construction only. Gluing them will not get you the sound of a set neck as it is more than a glue VS screw thing.
Gibson, as far as I know, has used two different types of joint. The long tenon joint was used in the beginning, somehow along the way it changed with the short tenon joint. The guitars that have the long tenon joint these days, are those of the Historic line.
I'm thinking these days: if you try to build a bolt on neck with a pocket in this kind of volume, perhaps you got the kind of sustain that's spoke about Les Paul... Perhaps Warmoth can do it as *Special Warmoth Series* someday (hint ;) )
Only the Les Paul had the long tenon, which was changed to short on its re-introduction after some years of nonproduction.  The SG changed its neck attachment from one that was glued more on the bottom, to one that has glued support on the sides as well.  The newer style attachment (from the mid-late 60's) is stronger.  Gibson has also made neck-thru-body designs (Firebird, maybe others), and has done bolt ons (later L6s, S-1, Maurauder, etc etc).
On thinking of the SG joint (original), its not to dissimilar from taking a bolt on neck and setting it in its pocket with glue.  With mostly the bottom of the neck being glued (and top of pocket) there is a strong tendency for the wood to delaminate its fibers and you get a two piece guitar.  Having a side supported pocket (later SG's, newer LPs) is a much stronger way to do things, and why you can't just "superglue" a bolt on neck into its pocket.
I'm thinking these days: if you try to build a bolt on neck with a pocket in this kind of volume, perhaps you got the kind of sustain that's spoke about Les Paul... Perhaps Warmoth can do it as *Special Warmoth Series* someday (hint Wink )
you might be thinking of the kind of bolt-on neck joint that PRS does. I think their bolt-ons (the CE models) use the same joint as the glue-ins , they just use bolts instead of glue.
Brian
If this thread doesn't die soon I'm going to post another pic of a marginally clad ex-girlfriend....
You will regret saying that! :)
ok here goes:
I don't really need a set neck and don't want to glue any neck.. I am changing my mind too often so I want to be able to swap things around!
there you go, now where's that ex-girlfriend?
how about a neck pocket that goes all the way up the neck, as if fenders wasn't bad enough.  what a neck contour, no thanks. extra frets, na
extended neck with a shorter and smaller body, don't even think of it.
this in support of our friend Jack. please forward this thread to all your buddies
