Seeking guidance in humbucker wiring
NowhereMan
My latest project is a Strat with 2 humbuckers, 1 volume, 1 tone and a Strat-style 3 way switch.  The pickups are a SD 59 Trembucker for the bridge and a regular 59 for the neck.  The neck pickup is on order and I just noticed that it's not a 4 conductor like my Trembucker.  Is this going to be a problem?  I've studied numerous diagrams and haven't found one for this particular set up; they all show 4 conductors for the neck.  Cash and prizes to whomever can describe or draw what this wiring job is going to look like.
Use this SD Tele diagram and you'll be good to go:
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=tele_2hum
For the single conductor pickup - just follow the above diagram and hook the black wire where the black is shown and connect the braided shield wire covering to ground.
Ditto what Jack said for the wiring diagram.  For SD, solder and tape the red and white together for series out-of-phase.  The black and green are your leads.
