SonOfSobek
I recently purchased a lot jr double cut style body to use with an old 1980s Kramer Pacer neck I had sitting around. The body doesn't have any holes drilled yet, which is good because the neck has been previously mounted on its original guitar. The issue I'm running into is that, currently, I've had little luck finding a neck plate that fits (the Kramer necks had 2" spacing on length, but narrower on width, for the screws) so I'm resigned to using ferrules for mounting it. My question is, I think these will fit, since the width of the holes is narrower, but, if I was going to do this, would it be reasonable to shape the heel to a more ergonomic shape than the traditional "block?" Since it's a double cut, and basically has both sides open, I don't want to take off too much wood, just "round" it up a bit. Anyone have experience with this?
