kwood69
So I'm in the middle of a build, ordered a neck spec'd for the Schaller M6 tuners, confirmed this on the documentation that came with the neck. Warmoth must be using a worn-out drill bit because the holes are so tight that the tuners squeak in the wood if I try to force them in.
I guess I need to ream out the holes a tiny bit, is there a good quality reamer or other tool recommended for opening up the holes a tad?
Thanks.
Thanks.
