I gotta set of m6 locking with the pins. Just check and the piece that goes in the tuner holes is 9.88 mm seems to be correct but I cannot get them in with decent amount of pressure.
Tuner holes often need to have a little finish removed that may have got in the hole or need a final adjustment for your tuner to fit. An easy fix is to put some sandpaper around a pencil or similar and rotate it in the tuner hole a couple of times, check the tuner for fit and repeat until it fits.
