I'm putting together an all-Warmoth VIP with Schaller 456 bridge, and I've noticed a strange dull/buzzy sound on the B string, almost a bit like a sitar. It affects the string the whole way up, even on the final fret, and only that string, so I don't believe it's a problem with action/neck relief or fret dress. One thing I did notice was that with the string removed, the saddle adjustment has a bit of "slop" in it, although one or two other saddles showed similar movement. I've wondered if the saddle V needs to be filed slightly, or if it could be a manufacturing/metallurgy problem with this particular B string. I also wondered about replacing the e-clip in the saddle adjustment screw with a slightly thicker one, if I can find one. However, I'm reluctant to modify the bridge in any way in case it turns out to be a defect and I need to return it.
The bridge also has quite a strong resonance, around 350 Hz. If you rap it with your knuckle it almost sounds like a gong! Is this normal? Maybe some foam rubber padding between the bridge and the tailpiece might help?
Thanks for any suggestions!
