Hi all :icon_biggrin:
Well where off & running again …… :icon_scratch: .... forget what # build I'm up to now :toothy11:
Called .... 'Redback' ..... It's a Strat with GK-3 installed :toothy10:
Strat Body & Bits ...
High Grade Red Quilt Maple
Alder (solid)
Rear Routed
Contoured Heel
Red Dye on Top
Transparent Red on Back
Black Burst on Edges.
Natural Masked Binding
P-Rails (Neck)
P-Rails Hot (Bridge)
6-Hole Vintage Tremolo
3 Way Strat Switch
1 on / off / on Mini Toggle Switch (for P-Rails)
2 x CTS 500K Pots 1 x Orange Drop Capacitor
1 x Volume, 1 x Tone, 1 x GK-3 Vol
2 x Up / Down Buttons
Roland GK-3 Internal Installation
13pin GK-3 Midi & Mono Input Jacks
Neck to come shortly (just bought yesterday) + custom Dougie Neckplate :icon_thumright:
Neck Spec's ...
Warmoth Pro Raw Rosewood
Rosewood Fretboard
Stainless Steal Frets SS6115
1 11/16" Nut width
Graph Tech Black TUSQ Nut
10 -16" Compound Radius,
Standard Thin Neck
Cream Dot Inlay
Cheers Updown :blob7:
Showcase Neck pic's …..
REST OF PIC'S SHOULD TELL THE STORY :glasses9:
ORIGINAL BODY
MARKING & PLACEMENT OF GK-3 PICKUP WIRES
DRILLED SMALL HOLES IN THE MARKED OUT BIT ..... :doh: FORGOT TO TAKE PIC'S OF THAT
DRILLED 1/8'' HOLES, THEN CUT THE SIDES TO EVEN UP
PERFECT FIT :icon_thumright:
DREMELED OUT THE HOLE LARGER TO CONTROL CAVITY AREA & THE BACK WALL FOR WIRE
YEP ... STILL PERFECT :icon_thumright: CAN USE THE 6 HOLE VINTAGE TREM HOLES TO HELP LINE UP THE GK-3 PICKUP
CAN JUST SEE SOME PLAIN WOOD, WHERE THE WIRE CURVES DOWN ..... SO
I USED A BLACK PERMANENT MARKER TO COLOUR WHERE THE WIRE GOES .... BINGO !!
Should be no more than 1/8'' between the Hum mount ring & the GK-3 Pickup when all put together anyway :icon_thumright:
No turning back now !! Cheers ccasion14:
Alder (solid)
Rear Routed
Contoured Heel
Red Dye on Top
P-Rails (Neck)
3 Way Strat Switch
Neck Spec's ...
Rosewood Fretboard
1 11/16" Nut width
Standard Thin Neck
Cream Dot Inlay
ORIGINAL BODY
