Rear Route and Push Pull Switches
partialdoctor
Hi guys... I have a new strat coming this week and I need some advice. I will be using two humbuckers. The strat is rear routed with two F holes and is chambered. Zebra top, mahogany back. The drilling is for one volume, two tones. I plan to use one volume, one tone, and one three way switch. I would like the volume and tone pots to be both be push/pull for coil tapping. I realize I'll have to enlarge one hole for the three way switch, but I have two questions:
1) Will the 3 way switch have enough length to fit through the rear route to the front?
2) What is the depth of the rear route cavity? Will long shaft push pull pots fit? I understand that regular shaft ones will be too short to make it through the body.
Thanks!
PD
