riverbluff
If you buy a body from the showcase that is already drilled for a bridge, for example an LP body drilled for a TOM bridge, is the proper neck angle already routed in. I know Warmoth offers the option of neck pocket routing to eliminate the need for shims, would that still need to be done to a showcase body.
Also, the stud inserts for the bridge, do they just press in? Is this something that is fairly straight forward or is it to the buys advantage to pay the extra $10 to have Warmoth do it for you?
BT
BT
