Since I've tried them, I'll never go back to Push-Pull pots. Looking for a source for Push-Push audio pots with solid shafts. I see Allparts has them in split shafts. Any idea of a source? Thanks all.
Thanks all. I've tried the brass sleeves, but the knobs still don't tighten up well. I'm going to go in and try to pry open the split shaft to make the sleeve fit tighter.
alternatively, you could order the split shaft push/push pot and buy a replacement knob that pushes on. In researching, it appears that Bourns makes the push-push pot with a solid shaft that fender uses, but they don't seem to sell it to the general public.
