persistence48
I am researching how to properly ground copper foil when used to shield the control and pickup cavities in a future build. I will have my volume pot directly screwed into the body, which suggests that given the back of the pot will be grounded, that will inherently connect the ground to the foil without need for a separate wire connecting the two. However, I will be shielding two humbucker cavities as well, which will not have a direct connection to the shielding in the control cavity. Because of this, will wire need to be ran from the back of the volume pot to the foil in the pickup cavities to ensure a common ground?
