S
swarfrat
Graffiti62 said:Trust me, the last thing I'd ever do is bash Canada
Aww but its such great fun!
SeanM said:Graffiti62 said:I know that there's a messload more to Canada than K-cars, Red Green and Trailer Park Boys. A day doesn't go by that I don't play at least one April Wine, Kim Mitchell, Max Webster or Rush track. Seriously some of the best and hardest working musicians have come out of the great nation of Canada, and sadly have not received nearly half of the recognition that they deserved for the hard work they put in. Many of the chops I know I didn't even know until I was exposed to the music when I would listen to Toronto's Q107.
As a matter of fact, "Sign of the Gypsy Queen" is playing on my PC right now.
Trust me, the last thing I'd ever do is bash Canada--I have too much respect for the nation to do that.
I didn't take your post as bashing Canada at all. Just thought I'd throw up some racing examples.
And theres nothing wrong with a K car, it's a nice reliable automobile........... :icon_thumright:
Dan025 said:SeanM said:Graffiti62 said:I know that there's a messload more to Canada than K-cars, Red Green and Trailer Park Boys. A day doesn't go by that I don't play at least one April Wine, Kim Mitchell, Max Webster or Rush track. Seriously some of the best and hardest working musicians have come out of the great nation of Canada, and sadly have not received nearly half of the recognition that they deserved for the hard work they put in. Many of the chops I know I didn't even know until I was exposed to the music when I would listen to Toronto's Q107.
and if the k car happens to have a 2.2 liter turbo 4cyl in it it will likely spank all the rice rockets zipping around the streets today. seriously i saw a fwd caravan with a 2.2 run 12.0's in the quarter. and it didn't take that much money. turbos are fun!
Don't forget about the Dodge Omni GLHS. I see one around the autocross tracks every now and then.
SeanM said:UPDATE!
Just did some catching up and finally nailed down my front suspensions geometry minus the rack toe arms. I will be using Bilstien Coil overs in all four corners.
Let me know what you guys think. Keep in mind, there is still no extra bracing. Trying to find time to get to it.
Miskatonic said:If I ever have the money I would like to build the following.
This:
With This:
And This:
And This:
SeanM said:Anti-dive can be done on a car like this, and some drivers may like feel of it, but from my days racing Formula 4 cars I found that with the way I drive it tends to create some under-steer. In this case where the weight balance is virtually 50/50 (estimated 47/53) along with the weight and power the nose dive through the corners helps to load the front tires. Provided the rest of the suspensions is adjusted to accommodate the load transfer.
That being said, the layout that is shown is by no means the best way to go about it. That is a base line so that I can continue the overall design, final tweaks and adjustments will be made during final planning and fabrication once the motor, tranny, rear end, and all the major components come together. The arms and mounts will be fabricated by me, not the shop that is doing the rest of my cutting and bending, to allow for on the fly adjustments and during tuning if I realize I need to change something, I can always redo it. Worse comes to worse, I can go total vintage and put solid axles front and back :icon_thumright:
Dan025 said:SeanM said:Anti-dive can be done on a car like this, and some drivers may like feel of it, but from my days racing Formula 4 cars I found that with the way I drive it tends to create some under-steer. In this case where the weight balance is virtually 50/50 (estimated 47/53) along with the weight and power the nose dive through the corners helps to load the front tires. Provided the rest of the suspensions is adjusted to accommodate the load transfer.
well that way the wheels are always perpendicular to the ground right?, at least until you hit a bump. anyway ive seen cars go pretty fast with solid axles front and back, but it is usually in a strait line or on the dirt.
Dan025 said:sounds sweet :icon_thumright: anything exotic? or unusual about the "engineering samples?"
