too many people get cold solder joints from too low of heat, I'm in the hotter the better camp.
But to your question, unless the solder joint is almost falling apart, there should be no buzzing, a bad solder joint, ot rather a cold solder joint is just a high resistance spot, it really shouldn't cause a buzz. If it is really bad it may cause buzz, but that bad of a solder joint is really bad. and I agree with the above posts, nice and shiney is good
