Superbeast520 said:I dont buy sperzels either because I found them to be lacking as well, they have a low gear ratio and yes they actually do slip especially on higher gauge strings, I found they develope slack points after a bit of use
Pardone for the broken record.. but they cannot, do not, and will not slip, at least not in the gearing. The locking mechanism might not grab the string as it should... that could happen, but the gearing cannot slip. Slack points... if you tuned UP adequately, you'd not have the issue with any tuners.
Folks get into the habit of detuning just a little when the note is already too sharp, then tuning back up and saying that must be ok. In fact, you should detune a decent amount, so that when you do tune up, you've eliminated all points of slack.
