S
swarfrat
I just wanted to put this out there.
Piezo's are not just for fauxoustic guitars and MIDI controllers. I have to say that I actually LOVE the Ghost saddles / Acoustiphonic into a medium gain amp cranked. It absolutely rocks, and it's totally buzz free. (It has other noise modes - like bumps, thuds, and I had to dampen the strings behind the nut and the tremolo springs for my own tastes, YMMV)
It's kinda tight and crunchy, makes a really nice rhythm drive crunch. You probably want to use the 'dark' switch (as luck would have it, I actually wired mine so that 'dark' is pushed in, and 'normal' is pulled up. It's absolutely imperitive though that you use the correct dampening material. I used a hand selected, period correct vintage 80's sock tie, woven in between the strings on the headstock, and wrapped around the tremolo springs. I used a burgundy one that I had on hand, as it didn't draw attention to itself on the Wenge background.
Try it. You may like it. If you ever find yourself dealing with a recalcitrant Neon sign, it might even be a life saver.
