I own a warmoth strat with the following specs:
Body: Black Korina HSS
Neck: Pau Ferro on Goncalo alves
Bridge: Wilkinson
Current Pickups: SD JB (bridge), SD Vintage Rails (middle), SD Cool Rails (Neck)
Pots: 500k
My problem is with the tone.
I had a SD Custom SH5 in the bridge and swapped it with a JB. The bridge pickup sounds ok but lacks attack and punch. When I pick a string it sounds as if there's a volume swell, its not punchy.The neck pickup however has the same overall quality but it is really dark and muddy.
I'm using my guitar through a Hughes and Kettner Tubemeister 18 and I'm just wondering if the problem is the guitar itself, the pickups or the rig.
Can you recommend other pickups?
Bridge: Wilkinson
Pots: 500k
