Pau Ferro / Pau Ferro - mahogany super strat.
Steve_Karl
Thanks everyone for the excellent information sharing that helped me get to this point of starting an other build.
Pau Ferro on Pau Ferro boat neck - straight 12" radius - SS6100 - 1-11/16" nut width
solid mahogany body - recessed wilkinson - 2 humbucking
and also graph tech acousti-phonic saddles and pre-amp isolated
(seperate from the humbucking system) to it's own 1/4" output.
I'm going to grain fill the mahogany body with chocolate brown colored filler
and then build up layers of Min-Wax wipe on poly satin.
After I tried the Min-Wax on my maple neck I'm done with Behlin's Master-Gel.
I think the Min-Wax is much easier to use and seems to build up better and to a stronger finish.
Hi-res pictures available here:
https://goo.gl/photos/C4mJavGzvsWGJcAR7
I'll be taking my time on this but will add pictures when I make progress.
Thanks again everyone!
Mmm, mahogany ... brown ... mmm ...
Takes me back to 1975 and my first "proper" guitar, a Gibson SG.  :)
Anyway.
That looks good and looking forward to your build.  :icon_thumright:
Lovely parts.  You might wanna seal that body before you grain fill so you avoid staining the wood with the tinted filling compound.
Nice neck!
Great choice on jumbo SS frets too - you have similar taste to me it seems...
I approve!  :icon_biggrin:
Ahh yes. Thanks for the reminder Bagman.
I found my step by step instructions that I collected when doing the last 2 so I'll follow the same instructions.
Man, the neck itself is a piece of art. I hope it still stands out when it's mated up with that gorgeous body - this one is going to be very exciting to watch come together. Keep sharing the progress!
Thanks for the encouragement (everyone)
Will be photo journaling the whole process.
First steps:
Neck get's tuners installed and press in the studs for the wilkinson
Test string-up to verify neck allignment
then if good
body goes into shop to get a second 7/8" butt hole so I can isolate the graph tech acousti-phonic system from the magnetics.
Yesterday checked all supplies and only needed to order a new bottle of Birchwood/Casey Sealer.
The old one 1/3 of a bottle turned to thick goo and I don't know how to thin it.
Everything else is good. Plenty of sand papers up to 600 ... and a barely used micromesh package.
Nice! I love that combo on my tele. Pau/Pau Neck and Pau top/Mahogany body. Pau ferro might be my favorite neck wood
HOLY FLIPPIN PARTSCASTER :blob7: That would be my dream neck for sure! Congrats. What a find. I am digging the boat necks I have gotten. Good work on your part. That is gonna be a great guitar.
Installing tuners ...
Thanks for the comments everyone and special thanks to Cagey for this post:
http://unofficialwarmoth.com/index.php?topic=21931.msg324468#msg324468
Especially about the press in fit, looseness being a "tone suck" being the reason we want them very snug
and later crayon wax.
I eventually arrived at my own (slightly varied from Cagey's) method last night after getting over being too critical about lining them up.
They were too tight to allign when pressed all the way in so I popped them back out to being loose and just sitting there alligned them by eye and a little 6" stewmac ruler laying on the back of the headstock against the ears that take the screws, got them all in the right place and used a very tiny twist drill to mark starter holes wearing my newly aquired Optivisor.
Then dremel drill first at 1/16" then widened to 5/64" after marking both bits with masking tape with the help of caliper measuremet for depth.
Had smoke coming off both bits. Probably need 2 new ones in titanium this time.
Used candle wax on the screw threads and all is good.
All high quality photos here:
Studs installed - gently pounded in with a wooden drift I made for an other build
Strung it up and played it. Very nice sustain and a lot of attack also ... just leaning jaw bone on the top of the body.
pretty cool...straight forward and classy... :headbang1:
Preview
Thanks Dangerous!
Controls holes are done.
Master Vol. for magnetics plus 2 concentrics = Vol/Vol and Tone/Tone. Phase switch.
Vol. for acousti-phonic system.
2 isolated 1/4" outs.
Now on to body finish when I get some time.
High quality images here:
https://photos.google.com/share/AF1QipNojcHX-w3Ont76-J6N_-x6xd60HeS3HGhPlcFZCCTBBuQlT_RuBP2fMuhVvsmRRA?key=WW4tcm43bzZZeml1bzNWUWdQQ2kwY05ZdC1IMmNR
4 coats of Minwax satin poly applied (4 or so to go) and
fret ends done and polished with 3M polishing papers (thanks to Cagey for the great info. ! )
I didn't do the top 5 on the low E side so you see an unfinished one there for comparison.
