I can't argue with the schematic of the active/passive switch, but I've seen too many with or without a switch, with a dead battery, produce no sound.
Well that's the issue then, you are referring to basses without a passive option.
I honestly think it's completely and utterly ridiculous that any bass with a preamp be built without an active/passive switch, regardless of how much of a priority you put on passive functionality.
When you get into 25K volume controls placed after the output of the preamp rather than 250K/500K volumes placed before the preamp, you are going to lose the volume control in passive mode, because trying to run a high impedance output from passive pickups through such a low value pot would kill most all of the output, but even with no control over your volume, it's better that you at least have a signal so you can get through a gig if your battery dies or something.
Some preamps are voiced to color the sound, even when set flat, either to put their signature sound on the pickups, or sometimes to make up for the pickup's shortcomings, so trying to run certain pickups/basses passive can sound like crap, but again, it's better to have something to get you through a gig if a battery dies or something.
I should note however, that I have extremely high expectations from my electronics though. As you guys should have seen from the way I choose to wire my basses.
I may be a bit biased as to what a bass should be.
