rightintheface
http://cgi.ebay.com.au/ATTENUATOR-FOR-FENDER-HOT-ROD-BLUES-DELUXE-DEVILLE-TWIN_W0QQitemZ200434614405QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2eaad58085#ht_2962wt_788
i've just stumbled across this concept. surely this is better for an amp than a power soak/attenuator that goes between the head/speakers? my local tech hates power soak attenuators. said something about putting a giant resistor in front of all that signal and then going max vol on your amp can be damaging. said it was like a car: just because it says it can do 240km on the speedo, doesn't mean it's DESIGNED to run that fast. eventually things wear down and break. said it was a similar concept for amps. just because they CAN go to ten, doesn't mean they should.
anybody got any expert advice on this? i imagine alot of people will say "i use an attentuator and it's no problem", but from a purely engineering side, is it not potentially damaging? i honestly don't know enough about amps to comment IMO. :tard:
surely the passive volume attentuator in the fx loop would work just as well, and heappppppps cheaper? or would you run into tonal problems?
