dmraco
I recently finished a neck with a rosewood fingerboard with poly. I ran the poly up onto the sides of the fingerboard only, the same way WARMOTH does. I noticed a small area that the poly is not drying and is remaining tacky. The Poly did not take. Could this be a oily spot on the rosewood? Will this eventually dry up?
It is on the underside of the neck so it is not seen, and the tackyness is fading and the undried poly is worn off that spot. I would like to apply some more poly so it is all the same....
Thoughts???
Thoughts???
