I have almost finished the shaping on my formerly-paddleheaded 7-string neck.
I want to tint the entire neck a light amber. I necessarily have to use water-based polyurethane as my finish coats (smell...). I know that Warmoth puts some kind of light sealer on their necks. What I have done previously to tint a Warmoth-sealed neck is to mix up a strong concentrate of powdered amber dye (from L.M.I.) in water, then just tint a batch of water-based polyurethane to do the neck with - 6 or 8 thin coats an hour or so apart. However, I have now removed some of Warmoth's sealer from parts of this neck.
To dye an unsealed body, I mix up powdered dyes in water, dye the body, then seal that with Zinsser's Bulls Eye Sealcoat, which is a wax-free shellac that seals in the dye. Then I can put on clear water-based polyurethane with it lifting the water-based dye. To dye this neck evenly, should I:
A: sand off ALL of Warmoth's sealer, dye it, then seal it, then finish it;
B: put on a coat of Sealcoat all over everything, then the tinted polyurethane;
C: go straight to the urethane stage, because Warmoth's sealer won't affect the absorption;
D: something else?
I'm leaning towards "A" because it seems most predictably error-resistant, but any and all advice would be appreciated.
P.S. (I need to get this sealed up real quick, before jackthehack's "ex" arrives....) :guitarplayer2: ->
ccasion14: -> :blob7:
![3rdAct007.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2F3rdAct007.jpg&hash=12d080a97fec4d700ef93c7f26bbd9cb)
![3rdAct006.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2F3rdAct006.jpg&hash=8ed8fdd259df13782cdd42938413ea60)
D: something else?
