joelavely
I'm a beginner in lutherie work. Just learning for my own fun. Tried to approach nutwork last night. I had ordered 10 "nut blanks" on Ebay, and they look great, but they are HUGE. Literally large enough to make two or four electric nuts from each blank. Problem is, I don't have the tools to cut the bigger blanks down to proper rough size, then actually do the "real" work (nut slots and proper sizing to the guitar).
Questions:
1 - Where do you all source properly-sized nut blanks? I want to cut the slots myself, and I realize a little bit of sizing will be necessary, but these are WAY too big. Probably designed for something else and I'm an idiot.
2 - How do you properly shape the top of the nut to match whatever radius you want? Seems like freehand would be questionable.
3 - If the slot on the guitar where the nut sits is radiused, do you flatten it, or do you radius the bottom of your nut? If you radius, I suppose #2 above will answer how. If you flatten the nut slot on the guitar, what tools do you use to get it flat?
4 - For those of you that buy bigger pieces of bone (I have read about folks buying dog bones in pet stores and cutting them to size), what tools do you use to cut and shape the bones to "rough" blank size?
ASIDE: I spent about two hours going through different tools to get the bigger "chunk" cut to a proper nut size. First, I hand-sanded for a LONG time before realizing that wasn't going to get me there. Then, I took a Dremel saw and cut one in half, which was helpful. Then, I remembered I have a hand sander that vibrates, so that did a great job of getting a LOT of the extraneous material cut away. Meanwhile, there is bone dust ALL OVER my damn basement. Ultimately, the stupid nut broke in half in my vise as I was trying to finally sand it. The moral as always - I don't have the right tools for this job!
Lavely
Questions:
Lavely
