I disagree slightly. BBE has the habit of putting a Sonic Maximizer in everything they sell whether it be a compressor, crossover, or whatever. They throw the Sonic Max in there too. Although they gear them towards different applications, the sonic max itself is not application specific. There is no guitar, bass, or PA system Sonic Maximizer. The guts of the stomp versions are no different from the rackmount versions (which by their rack mount nature imply that go in the loop) other than the physical dimensions of the enclosure. Added to that, the BBE Sonic Maximizer technically is a (inaudible) delay. It is done in nano seconds, so you don't actually hear the delay, just the result of it. In other words it delays the bass and allows the highs to hit your ears first, then the bass, resulting in a less muddy, fuller sound. BTW, one of the rack mount Sonic Maximizers I bought came with a 2 prong power chord, no ground. The elimination of this ground may eliminate one of the parallel ground paths that can cause a ground loop. IMO, it's chasis becomes grounded/shielded by borrowing the ground of one of the other (hopefully) 3 prong power chords by being mounted in the same rackcase. But your's is stomp box, and while having no third prong (ground) on the power supply....this can get complicated. Try it with the battery and see if the hum goes away.
