I like Deft for semi gloss or satin
I like Cabot for full glossy
The two are compatible.
Cabot seems to dry out faster than the Deft glossy. A plus, so thats why I like it better. Deft takes long to get "sanding" dry. However, the Deft semi-gloss will dry very fast, and it buffs to a sort of "vintage gloss", not super mirror, but shiny in a dull way. Hard to explain, but... it is shiny, you can see sharp reflections in it, but it doesn't quite get to that full mirror gloss.
The re-Ranch stuff is supposed to be good. The StewMac stuff... has some problem reports.
The key with any lacquer is adequate drying between coats and before sanding - controlling thickness of the coats to ensure proper drying. That is - if you heap up the coverage, and make it really thick, it will take a long long time to dry to a point where sanding will create "dust" rather than pill up like an old sweat sock.
