Can you hear the difference?
i couldn't hear a difference, but then, i wouldn't expect to hear one if using a trembucker on a narrow bridge like the one in the video.
i'll be straight #honest, this was a weird test, mon frere.
the better test would have been to use a wide vintage bridge because that is where ppl (needlessly imo) worry about the magnetic fields of regular humbuckers not being ideal. i think players are more curious if a TB makes a difference in that situation. personally, I still think the diff would be insignificant, but at least the test wouldn't be the inverse of what p'up makers intend.
A couple things to note here. Seymour Duncan uses a wider bobbin to get the Trembucker spacing. Something about that wider bobbin makes them sound worse to me. The spread of the poles is also so far that the only real need for them is on vintage strat bridges with the 2-7/32" string spread. Additionally SD's "standard" spacing is a bit wider than other major makers so their pickups work for bridge spacings up to about 2-1/8"
Most other pickup makers offer F spaced pickups but retain the same bobbin size for both spacings.
In the video you make the generalization that Trembucker is the same as other makers "F" spacing. This is not correct. DiMarzio and others dont have the sonic disparity that a Duncan Trembucker has because of the bobbin issue.Yes, all this. And because Duncan's trembuckers have longer bobbins but still use the same number of wraps they use more wire and have a slightly hotter output than their humbucker counterparts.
So even though this test was done with the less-than-ideal hardtail bridge, the other differences were still worth testing.
Just feel its a very important distinction to make.
Actually not true. It's the same number of windings (which is what produces the power), but of course takes a bit more wire on a larger bobbin, so the increase in wire length produces a higher DC resistance which has zero affect on power output.Yes, all this. And because Duncan's trembuckers have longer bobbins but still use the same number of wraps they use more wire and have a slightly hotter output than their humbucker counterparts.
There is no sonic disparity with Trembuckers.In the video you make the generalization that Trembucker is the same as other makers "F" spacing. This is not correct. DiMarzio and others dont have the sonic disparity that a Duncan Trembucker has because of the bobbin issue.
I have to disagree. The JB has a more pronounced upper mid in the trembucker version.There is no sonic disparity with Trembuckers.
That's pure nonsense. The only possible difference would come from pole pieces lining up directly under the strings, and even that results in a miniscule difference.I have to disagree. The JB has a more pronounced upper mid in the trembucker version.
They have different DC resistance and longer bobbins which means a different magnetic field there is no way they can be the same.That's pure nonsense. The only possible difference would come from pole pieces lining up directly under the strings, and even that results in a miniscule difference.
DC Resistance has ZERO to do with tone, and the size difference is not enough to significantly alter the magnetic field.They have different DC resistance and longer bobbins which means a different magnetic field there is no way they can be the same.
