Check it out:
[youtube]https://youtu.be/QndUvW8cNTo[/youtube]
hosko said:Nice video Aaron, would love a graphic with all the profiles overlayed in different colours to make it easier to see the differences
BroccoliRob said:pubic domain and fair use
TheElvis said:If one digs the '59 profile, but wants to go unsymmetrical, would you recommend the Wolfgang or the SRV?
Is it fair to say the Wolfgang is the unsymmetrical standard thin and SRV the unsymmetrical '59?
Cagey said:Good job, as usual, Aaron.
I've always thought the "Standard Thin" should just be called the "Standard", as the "Thin" part suggests a dimension that sorta exaggerates what it is, or might scare some off what is actually a very comfortable neck.
jco5055 said:Great video Aaron! One question based on a line you mention in the video: If the profile is the same, will a more narrow nut (let's go with the 43 vs 42mm) make a neck with the same profile feel thinner? If someone liked the EVH profile on a 43mm neck, should they maybe consider going with the SRV if they wanted their next neck to be 42mm?
