Patrick from Davis
That is all you need to do for the Volume pot replacement. The Fender one has an odd "frame" around it that must be unsoldered as well. Another couple of tricks are to make sure that the Reverb pot is an audio taper, the reverb circuit is basically a mini amp in your amp so a linear pot doesn't make much sense, and to make a master volume in a pedal box that goes in the effects loop if you want to crank the preamp for Dire Straights-esque tones without creating a blast radius around the amp.
Other good ideas to think about with that amp, reflow the solder joints on where the tube sockets connect to the board. They tend to take a beating. This next point is one of the most common sources of trouble in these amps. There are two wire wound 5 watt ceramic power resistors in the amp, 470 ohms, that should be replaced with 330 ohm (or close to that) resistors. They are essential to the switching system in the amp, and they tend to overheat the board. By dropping the resistance a little the problem goes away. If you look at the solder joints on those two resistors, it can be quite ugly. But for a couple of bucks, you can fix it yourself.
