Believe it or not, these were all Showcase items. One view I forgot of the out-of-the-box neck:
That black one is in the process of becoming my signature bass. I completely shielded all cavities including the bridge route with copper, and then made sure everything was electrically connected/grounded. Then I laid a copper foundation for the bridge, and installed a Schaller 463 (all hardware is/will be gloss black). Also installed a tele-style jackplate (a machined one, not a stamped sheet metal one. For tone, I put in three Fender split-coil humbucking J pickups. Currently, the body is in Texas, having a Turnstyle Switch and custom electronics installed. When it gets back, I plan to have Mike Lull install the neck & tuners, set it up and have it Plek'd.
Updown, you can't have it. This is going to be my first high-end bass. (The other one is going to be my second, so you can't have that one either.)
Scuffcakes, thanks.
Cagey, the bridge pickup is in the normal position. I had Warmoth custom route the two neck pickups 2" apart from each other. The tone possibilities are going to be tremendous, especially with the electronics package going into it (details later).
Yes, 3-pickup basses are uncommon. However, it will not be my first.
