The Pink Elephants
Hello to everyone!
I'm a new member and I'm ordering a Tele this week, but I have some doubts, since it's my first Warmoth built. I've sent an email to Warmoth sales about it, they haven't answered yet. Meanwhile, let's see what do you think about my project, and I hope you can answer some of my quetions. I'll copy the email I sent Warmoth, for the sake of lazyness
Hello from Barcelona!
Next week I'm oredering my first Warmoth body and neck, and I'd wish to clarify some things and ask for some advice before I do.
My idea is to have a Telecaster shaped body (I'm still unsure about the wood), routed for just one Humbucker (probably a Duncan Custom), a tone and a volume. Mounted on a Gotoh HumbuckerTele bridge. Covered with standard pickgaurd (routed for the humbucker), and finsihed in a solid color.
As for the neck, the idea is to get a maple 25.5" Warmoth Pro, stadard thin profile, SS6105 frets, Tele headstock, Satin finished. Not sure about the fretboard wood. I'll be puting the schaller Mini Locking tuners.
So the questions I find myself asking are:
. Will the pickup fit Ok in the Gotoh bridge? I won't need a mounting ring for that one, right? Would you reccomend the Gotoh system over the TuneOMatic, for example?
. About the copper shielding, is it necessary for every guitar or just for the ones with single coils? Would I be ok without it?
. Intonation wise, the bridge, neck, nut and frets I've chosen are a good match?
. Will the Schaller miniLocking tuners fit on the standard holes?
. Do I need string ferrules?
. It's necesarry (or recomended) to put glue on the screws (for the neck, the pickguard) for preventing them to get loose?
. Will the MJ1 jack fit on the Tele body, or do I need the ES1C? And the neck plate, the NP1C?
. Given the neck specs I want, what would be better, to get nut material and get a Luthier tu cut it up, or to get one of your precut nuts? Even if I assamble the gutiar myself, I'll be bringing it to a luthier for adjustment, I just want to see if I can get the nut before it.
. I'm toying with the idea of getting the cavity of the neck pickup done, just in case I wish to add one later on. Of course, it would be hidden behing the pickguard. But will getting this chunk of wood removed have a noticiably effect on the instrument's tone?
. I'm having trouble chosing the woods. I'm debating between Alder, ash, and swamp ash, mainly. Also about the fretboard, between maple, rosewood and ebony. What would be your advise? Keep in my mind this will be a rock guitar, with a kinda trebly high output humbucker. If the pickup choice I made isn't very wise, feel free to recomend me another one. I play lead guitar in a punk - rock and roll band.
. And I know you can't probably get a exact date, but how long will it take for you to built it? Just a rough estimate. And I'd be very grateful if you could get me a shipping quote, too.
Sorry if there are too many questions, but this is my first build guitar and I want to make it right!!!
Thanks a lot for your patience and attention,
David
Thanks in advance to everyone here, too. :rock-on:
David
