Cagey
Mythical Status
phillip_h said:pabloman said:You're putting a Tele neck in a Strat pocket?
It will fit a standard 4-bolt strat neck pocket.
It's the other way around. A Strat neck will fit a Tele pocket, but not vice-versa. Tele necks and pockets are square at the heel, while Strats have a radius to them. The radius in a Strat pocket will prevent a Tele neck from seating back as far as it needs to. Not by much - it's probably only 1/8" to 3/16" - but it's enough to prevent installation without relieving the pocket. If you go in the other direction (Strat neck on Tele body), the neck will bolt right on but you'll have some small clearances in the corners of the pocket. Usually don't notice them because of fretboard overhang.
