rauchman
Greetings,
I have a mahogany Velocity body that I've been working on. Successfully created binding routes, however I screwed up with drilling the holes for the pots. On the front side, being the idiot I am, I used masking tape to prevent tear out when drilling the holes for the pots. When I pulled the tape off, it pulled some fibers from the body and wound up pulling up a good strand of fiber to where I now have a noticeable gouge in the wood, however the strand is still attached to the body and kind of hanging off.
Recommendations on how to fix? I saved a bunch of saw dust from routing the body bindings and was thinking of mixing the saw dust into an epoxy mix, and then applying, let dry and sand down.
