Hello,
Happy SSS Warmoth owner here.
I would like to swap my neck, which is 1&11/16" wide at the nut, with a neck that'd be 1 5/8" wide at the nut. (and also, thinner, btw)
Same ( 25.5" ) scale length
Same (modern) construction
Same (10"-to-16" compound) fretboard radius.
Only 1/16 of-an-inch narrower at the nut! (and a little thinner)
I'm worried about hardware compatibility!
Will my Wilkinson-by-Gotoh VS100 bridge still be compatible or set-able with the rest of the guitar?
Will a different string spacing affect the tone, as the guitar mounts unevenly-spaced SSS pickups?
...Or will the change in string spacing be negligible for both for the pickups and the bridge?
Thank you very much!
