JPOL007
Finally got the neck sanded into submission. Enough to try inlaying some of the neck engraving. Will have a ton more sanding getting the inlay sorted before dying the fretboard can take place.
I tried using the ground Calcite stone on some scrap maple and didn't like the look. The material needed to be larger in grain size to achieve better depth appearance. The engraving is not deep enough to allow the larger size.
I decided to use the crushed mother of pearl instead of the Calcite. Used Transtint black dye to change the color on the mother of pearl. Tried inlaying the Celtic cross at the first fret position. I need to go back with some smaller sized grains to fill out a couple of spots. I like to grain definition of this material better than the Calcite.
