HolographicUniverse
Hi all, about 3 weeks ago I received my first order from Warmoth. Super happy with it - fully exceeded my expectations!
I had ordered a swamp ash tele body and roasted maple neck. Both unfinished. I tested the fit of the neck pocket, and it was a good fit - the neck fitted into the pocket without any resistance, but there wasn't any side-to-side movement. I doubt I would have been able to hold the body up with the neck, without any neck screws.
Yesterday I tested the fit again, and it is now significantly harder - I am needing to push the neck quite firmly into the body. I can easily hold the body up with the neck without the neck screws attached. Note that when I am installing it, I am pushing the neck DOWN into the neck pocket, not SLIDING it. I am aware that the pocket does not have parallel sides - it is a slight 'dovetail'.
Understand that this is likely due to the change in climate. I suspect that it is mostly due to the swamp ash body - the roasted maple neck will be pretty stable. I haven't done any work on the body and neck - they have been sitting in a dark, dry cupboard.
My question is - should I sand the pocket to make the fit looser, or just accept that the fit will be tight when I get around to assembling it (when my other parts arrive).
I also had a crazy idea about adjusting the humidity of the room in hopes that the body would return back to the state I received them in 3 weeks ago. Does the tight neck pocket indicate the body swelled or shrunk? I'm in New Zealand, temperature has been around 15°C/59F, 75% relative humidity.
