Hi all, I have a Warmoth body and SuperWide neck, and was wondering about interchangeability with other guitars. The heel seems to measure larger than spec: 56.16 mm (2.211") at the heel of the neck itself, and 56.2 mm (2.213") across the neck pocket in the body. This is considerably larger than the Warmoth spec of 55.5625 mm (2 3/16"). Aperio Guitar give 55.626 mm (2.19") as typical for Fender factory parts.
My Godin Artisan TC neck measures 55.96 mm (2.203") at the heel, but even the pocket on that is too small for the Warmoth neck (and the Godin neck in the Warmoth body has a bit of angular play, although it's fairly snug otherwise). I don't have any real Fenders handy for comparison/testing.
Any thoughts on the discrepancy? Is the specified dimension prior to finishing? That would seem strange, as the pocket is unfinished and would be the logical dimension to specify. Something special about the SuperWide, or the angled neck pocket (for Schaller 456 bridge)?
