TonyFlyingSquirrel
Master Member
I had a Guitar Building book from Roger Siminoff about 20 years ago where he used T-nuts in the neck.
While the concept may be a good one, it does seem that the T-nuts do take up a fair amount of real estate in the material where they're implimented.
I think a smaller, re-engineered versions is called for, made of titanium or stainless steel, considering that once it's in there, it's never coming out, and that it will remain there under tension likely for many, many years.
I would think that a smaller billet of stainless steel could be tapped, and the anchor could be machine shaped square or triangled, instead of round, then the protruding teeth would not be necessary. The area of the neck shaft receiving these would be routed to shape (square, triangled) and the additional mass of wood in the neck would sufficiently anchor them. Heck, you may actually be able to epoxy them in.
