jackthehack
Epic Member
Rewiring this setup in the Parts'O'Caster I'm putting together, had tested these pickups in other axes and the net effect overall is completely killer!
Neck PU - Rio Grande Vintage Tallboy
Middle PU - Rio Grande Half Breed
Bridge PU - SD JBJr. bridge
It's wired straight with a .050 ceramic cap, with the exception of the JBJr., extra toggle is wired to split it (normal mode with the Rio Grande SCs) or put into parallel or series HB mode (Turbo mode). Not the cleanest wiring job, but a lot going on in a tight space.
The RGs give great vintage tone with added balls, the JBJr in split mode works well with them as a single coil bridge PU, in Turbo mode it just flat out screams. Will maybe get the rest of the build finished and posted later....
