musicman humbucker wiring
bassgasser
I have a question, i just recieved my Nordstand MM5.2 pickup (thanks to the advice of skuttlefunk) and i had one question about wiring it. I am going to do it series and the instructions say:
Black=Hot
Red+ White= solder and tape off
Green (plus shield) = ground.
My question is, there are all those wires but then there are frayed wires coming out with them, it that the shield? Any help would be great.
SkuttleFunk
yes, that should be the cable shielding IIRC. solder this together with the ground
I'm not in front of a MM pickup at the moment. I'll check when I'm back at the shop and post a follow-up if any correction need be made to this
Enjoy the pickup, and definitely post a sound clip when you get the opportunity
all the best,
R
