Multipiece necks with laminate accent
SandyCrack
Seen this on several guitars in the past and it's a classy look. Three piece maple neck w/ thin walnut or ebony laminates in between.
ibob74
Yeah, used to be the thing with "neck through" builds. Don't think you'll find any at Warmoth though. Carvin is the only company I recall currently doing that.
riarojr
the only companies i can think of doing that off the top of my head are some of the japanese ones like Ibanez with the 5-piece wizards (bolt-on and neck-thru) ESP Edwards line rockin the 9piece neck thrus which is somn i've only found on high end guitars-once again mainly japanese.  like i said i'm only listing the ones i can think of right away and i'm pretty sure there's more...
riarojr
oh, and i think that would look sexy as hell....i mean, you've seen the gecko necks in the showcase right???  :eek:  :party07:
-CB-
Gibson Firebird V and VII are neck thru multilaminate construction.
Ovation has a multilaminate neck on all USA models, maybe some of the imports too (I haven't checked).  For an acoustic, I gotta tell ya, that Ovation Adamas I've got... plays like a Strat (a Strat with .012's of course).
jackthehack
This pau ferro/ebony neck I found for cheap on eBay has a thin purpleheart laminate strip between the pau ferro and ebony board; you might be able to custom order something along those lines, call your friendly sales rep
