ChrisMC
I’m patiently awaiting my neck and body (hopefully mid to late May arrival time). In the meantime, I’m researching every inch of my build, and trying to prepare for any issues that may arise once the neck and body get here.
Mine is a Soloist build.
I am going with two humbuckers and a Schaller Megaswitch E 5 way switch (master tone/master volume). I read where ONE person had issues with the Megaswitch’s screw holes not quite lining up with the pre-drilled holes from Warmoth, and the holes on the switch itself needed to be ovaled out and then rigged with the proper size nut for the machine screw thread to get those switches to work with the existing holes.
....but it was an older thread and only one person that said it. Not to say that it wasn’t true and correct, but it was also from years ago IIRC, and who knows what may have changed since then.
Has anybody experienced this with the 5 way blade switch route (ie Soloist, rear routed Strat, etc) and a Megaswitch (Schaller)?
Just curious. I already have it. I already have EVERYthing (Thornbucker pickups, pots, cap, barrel jack, conductive shielding paint, potentiometer knobs, wire, solder, pickup mount screws for direct mount, foam for underneath the pickups, locking tuners, brand new original Floyd Rose unit, R3 nut, D-Tuna, brass claw and screws, big brass block, potentiometer knobs, etc etc etc...), just trying to plan before it arrives.
I’m curious if anybody had to modify their Megaswitch to get it to work and line up with the Warmoth 5 way blade switch route/screw holes.
Thanks!
Thanks!
