Hi fellas - been checking this site out for a while now (time spent on reconnaissance is seldom wasted, you see) but the guitars above has prompted me to sign up! Have had a strat similar to the above in my mind for quite some time now, and found a thumbnail pic on the warmoth site, but no other information.... is it commercially available through warmoth?
Hello Matt, welcome to the forum!!
You can buy a body and neck like this from the Showcase. The neck wood may not be as high of grade or you might get lucky and find an amazing piece in the Showcase. I ordered this body from the Showcase and the neck custom ordered. I have very specific tastes in neck profiles and wood quality so I was not having any luck getting what I wanted on the Showcase. Spend time shopping the showcase and see what you can find, if you can’t find it call Warmoth and they will walk you through ordering the parts.
Here is a list of what will be going into this guitar.
1. Lightweight unfinished left-hand Alder Strat with reverse orientation. I lacquer finished it
2. 1-piece left-handed Birdseye Maple CBS Strat reverse orientation neck. This one is a vintage modern with a 59 Roundback profile, 6100 frets and Kluson tuners.
3. Pickguard is a Parchment from Warmoth,
4. Pickups are special order Fralins from Callaham. They are the EJ/Hendrix/SRV set.
5. Miscellaneous hardware and plastic will all come from Callaham.
6. The trem block will come from DeTemple.
7. Reproduction Kluson Tuners will come from W.D. Music Products.
8. I use one 280K super pot for the volume and 250K CTS pots from RS Guitarworks.
9. I will be using a NOS 1963 ceramic disc capacitor on this guitar but I would suggest RS Guitarworks for capacitors. I like the LUX reproduction ones.
You can certainly use other sources for your parts these are just what I have settled on for my own personal builds from experience.
Good luck!
Greg
