Steve_Karl
The mahogany back is fine ... probably because it's more forgiving than a maple top?
The top:
Everything looked ok after 3 coats of Master-Gel and buffing with a white scotch brite ...
... i.e. until I decided to go the extra mile and use the pack of micro mesh I didn't use on my last build.
So, I buffed the final coat all the way up to 12000 with micro mesh and what I have now is
the quilt maple top feels like glass and reflects like a new car finish ... i.e. at certain angles.
Looking straight at it also looks great.
But ...
... at other angles, I think I'm now seeing down to the wood surface and possible poor preparation
of the initial raw wood surface, and also possibly not enough attention to coat 1 before doing coat 2, 2 to 3 etc.
My camera can't shoot a fast enough shutter speed to catch the flaws I'm seeing, so photos won't show it, but to my
eye, when tilting it under good light, I'm seeing what looks like open grain in the maple, and it's pretty ugly.
If I angle it a bit farther back I get a decent mirror and can see my tools on the desk reflecting in the surface, and it looks perfect at that angle. ( so what's going on with this ? )
I thought that the maple top would be good to finish after going over it with 320, but I'm guessing now that
I should have sanded it up to about 800 or even more.
Also, using a gray or white scotch brite ( 1000 - 1200 grit ? ) to scuff coat 1 and coat 2 wasn't detailed enough.
I should have read the instructions for the micro mesh before I did anything, which generally says
3200 - 3600 between coats, but seeing it now I'd want to go to 4000 or even 6000 between coats, just to be sure.
If I take it back to raw wood I'd just want to do the flat of the top and the beginning of the curved edges.
The curved edges look fine and aren't showing any of the flaws I mentioned.
I'd probably roll the rubber sanding block slightly over the edge but not as far as the mahogany side.
What do you think?
The top:
But ...
What do you think?
