swinginguitar
Is it generally accepted as "do-able" to route for a floyd nut on a strat style neck with the rod adjust nut at the headstock?
Most of the pre-made necks I see that are available for FR nuts are heel adjust.
can anyone confirm from experience that there is enough wood there for this with out bumping into the truss rod nut?
as a related aside, can any typical FR nut be shelf mounted (i.e. screwed in from the top as opposed to holed through the neck), or is it a special piece reserved for that use?
