GoDrex
2 volumes, 2 tones, 3 way switch.
What style of wiring is your favorite?
The more I look into it, the more different ways I'm finding to do this.
There's the method that on this site.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
then there are these:
modern
I ordered some pots from Wymore and their schematic looks different from these two - though it looks the same to me as the SD version. They call it "modified standard" - so what are the characteristics of that style?
modern
and vintageModern Wiring (above)
Pro - Because the tone controls receive their signal from the input of the volume pot, they are effectively connected directly to the pickup. Consequently, the volume pots' positions have no effect on the operation of the tone controls, which operate completely independently of the volume controls.
Con - The tone changes as you roll down the volume pot - there is some treble roll-off in addition to the volume roll-off. This doesn't bother some people at all, while it drives others crazy.
Vintage Wiring (above)
Pro - When you roll off the volume control, you don't have a corresponding treble roll-off, the tone stays consistent.
Con - The tone and volume controls are interactive, because the tone controls receive their signal from the output of the volume pots (rather than the inputs). Because the position of the volume pot affects the tone control, the tone control's effect is inconsistent. As an example, if you like the tone control set at 5 with the volume all the way up, then this may change as soon as you roll the volume pot down some.
