Bassjacker
So I have a J retro pre amp which is powered via a 9v battery. As well as this two pickups which have mini circuit boards with ground, hot and 9v. The hot and ground is fine and dandy and the two 9vs (one on each pup) are wired together. Now the question is where do i wire the two 9vs cable to to allow the leds to light up due to a cable being plugged into the stereo jack
