I think learning jazz depends a lot on how you want to play it.
In my experience, if you start copying solos of some greats, it takes a lot of time learning them by heart, and ultimately you might find that you cannot replace the parts you've learned smoothly in your own improvisation. If you do, you might still realize that you are playing licks. Plus, when you've worked on your soloing, you find that you only know a limited vocabulary on chords and cannot comp creativelly
To me, jazz is about forging your own vocabulary, and being able to play something personal.
To do this, i believe you have to have two skills :
- to be able to listen to what you are feeling as a person when you play, what do you want to play at a moment, and how musical is it? this skill depends on your ears, what you've listented to, what you like, your personality, how you feel on the moment, and it will be refined as you work on music and on the instrument.
- to be able to play anything coming in your head directly without any restriction, thought, delay, effort or frustration/fear.
For the second skill to develop, i think you have to work in a focused way on the instrument. that is: know your scales, your chords/inversions/drop on the whole neck, your arpeggions, know the tune you're playing on, knowing the name of the note you're playing, the names of the notes in the chord and the modes you choosed to play, etc etc
In my experience again, it is really easy to progress if you decide to work on one specific thing at a time. providing all other difficulties are easy, you only have one difficulty and your brain can assimilate that specific thing.
Providing you have a theoritical knowledge of what a major scale is, and how it can be harmonized, you can start working for years(!) on the instrument.
Here are some leads of things i've worked (and am still working) on:
- Learn your major scales: it really helps developing your neck knowledge. I personally worked in positions, using 3 notes per string always, it's easy for the triplets, it's easier to remember, and you will have to make a small move at the B string that will give a bigger span to each position. If your root note is on the A string, begin the scale on the E string anyway, going down until you have 3 notes per string. Learn all positions, slowly, with a metronome, using patterns: 1-2-3-4 - 2-3-4-5 - 3-4-5-6 - .to the highest note of the position on the e string, then . 8-7-6-5 - 7-6-5-4 and variations of patterns : 4-3-2-1 - 2-3-4-5 - 6-5-4-3 - 4-5-6-7 - .to the highest note on e, then . 8-7-6-5 - 4-5-6-7 - 6-5-4-3, ...
try using groups of 3 notes, in eight notes, then triplets, groups of 4 notes in eight notes and triplets. work the metronome up slowly. Work in one tonality over the whole neck, then try one position, and one tonality, then when it's done up and down, switch the tonality, following the 4th cycle, or try other modulations. this can be done with backing tracks or band in a box.
- My teacher showed me chords on adjacent strings only at the beginning it helps remembering them : you can find families of chords that are all possible ways of putting the notes 1357 on 4 adjacent strings on a guitar. families can be : 1573 or 5137 for example, there is at least 1 family per inversion. when you have them, play with a metronome, going to the next bass note. ex play one chord with the root on bass, then the next chord with the 3rd on bass. and go back and forth between them. then do the same with the 3rd on bass and the 5th on bass, etc until you assimilate them. when you know that, if you put the chords on 1 and 3, and a bass note between them on 2 and 4, you are doing a walking bass with chords very easily.
- Start playing the notes of the mode on the 1, beginning on each one of the arpeggio's notes.
- write down every exercise you decide to do in notation, it teaches you to read more easily, and teaches you a lot about making your own exercises.
These are some of the first things my teacher gave me in months of work with him and i feel this way of working really opened up my vision of music, practicing music, and playing music. it also opened my ears and mind to new possibilities and i learned some things that i thought were nearly impossible in a easy way.
I also learned a lot about the process of learning and in particular , that if something is too difficult, it's not because it's difficult, it's because you're not well prepared for it. so you only have to analyse what you need to be prepared, work on it, and do it again until it works.
hope that gives you some ideas for working jazz. that's the way that works for me
Best
