I'm just starting to lay out the wiring on my Strat, and I thought I'd do a reality check...
First off, is it worthwhile using shielded wires from the 5 way switch to the tone controls? The reason I ask is, I got some dual lead shielded wire at some point in my parts scrounging and this seems like a decent place to use it.
Assuming it IS suitable to use here... my question is, do I have to connect the shielding to a ground at the 5 way switch, or can I just put some shrink wrap on that end to keep it from shorting anything out and only connect it to ground at one of the tone pots?
I'm not at all well versed in electrickery so it seems strange to only have one end of the shielding connected to anything, but on the other hand if it's acting like an anntena picking up noise, why would both ends need to be connected?
So c'mon sparkies, help a clueless newbie out! :sad:
