croquet hoop
Very helpful indeed, thanks for the info
Thanks Bart.. :headbang:Black Dog said:I don't know how Kumo feels, but that neck plate is cool... :headbang1: Nice work Doug!
This whole build is really sweet and I would be proud to rock that girl.
:rock-on:
Kuro Uma said:croquet hoop said:This birdseye neck is gorgeous. How many coats of TO did you put ?
By the way, did you stain the wood directly, or did you put a coat of tinted lacquer ? If you stained it, is the liquid masking tape better than normal tape at preventing the stain from getting behind the mask ?
For the neck I did about 6 coats from the bottle. Then leveled it with 2000 grit and lemon oil as the lubricate. Then I used the aerosol Tru-oil and shot a final coat. After about a week it was hard enough to polish.
For the body used a bit of Tru-oil to coat and seal the natural binding. Then I used the liquid mask after that was dry. I've used the mask before without first using a sealer and it works well as it fills in all the tiny places that normal tape just rides over. This is all so microscopic. But i feel it seals better. I did apply the dye directly to the wood. Black first, sanded back, a royal blue, sanded back, then the turquoise.
Hope this helps.
crash said:Kuro Uma said:croquet hoop said:This birdseye neck is gorgeous. How many coats of TO did you put ?
Hope this helps.
What did you use for polish? I have never had any luck polishing Tru-oil.
DangerousR6 said:Hey Kumo, whatcha think...? It's just a ruff draft, but you get the idea... :icon_biggrin:
:icon_thumright:Kuro Uma said:I like without. Let's do that one!
That's how I met my wife, I said.."would you like to see a magic trick"... :laughing7:Great Ape said:Sheesh...not only is Doug a fair-to-middlin' stand-up comedian, he's also a pretty decent magician...in fact I'm tempted to say there're a couple of 'em at work on this project!! :hello2:
DangerousR6 said:That's how I met my wife, I said.."would you like to see a magic trick"... :laughing7:Great Ape said:Sheesh...not only is Doug a fair-to-middlin' stand-up comedian, he's also a pretty decent magician...in fact I'm tempted to say there're a couple of 'em at work on this project!! :hello2:
"fair to midland"...that's pretty good, I doubt anybody else get's it, but I did... :icon_biggrin:
